-   -   distributor hei que. (http://www.hotrodders.com/forum/distributor-hei-que-226127.html)
39chevy 11-15-2012 04:22 PM
After fresh reb motor (350) turns over few times and when I loosened the dist screw to turn for better timing, motor was off, dist turned like it was spring loaded. Does this mean I am off a tooth or is this normal? Advise, thanks Dana
techinspector1 11-15-2012 08:19 PM
No, not off a tooth necessarily and not normal necessarily. In order for the dizzy to move like that, there would have to be some binding between the housing and the shaft. Either the housing is warped or the shaft is bent or something along those lines. Disassemble the dizzy and find out what the problem is before you hurt something.
hcompton 11-15-2012 08:22 PM
You can try taking the cap off and see if the mechanical weights are getting hung up when you turn it. Did it hit the fire wall during install it mau be bent if the mechanical advance is pulling it back. Alsonare the wires connected and pulling on it or vacum line.
