No, not off a tooth necessarily and not normal necessarily. In order for the dizzy to move like that, there would have to be some binding between the housing and the shaft. Either the housing is warped or the shaft is bent or something along those lines. Disassemble the dizzy and find out what the problem is before you hurt something.
You can try taking the cap off and see if the mechanical weights are getting hung up when you turn it. Did it hit the fire wall during install it mau be bent if the mechanical advance is pulling it back. Alsonare the wires connected and pulling on it or vacum line.
| How do you remove the distributor gear on an HEI distributor? | against all odds | Hotrodding Basics | 4 | 01-31-2012 09:58 PM |
| Which GM HEI distributor? | Madmax305 | Engine | 8 | 08-23-2010 08:34 AM |
| HEI distributor | Gun Laker | Engine | 4 | 03-21-2010 02:28 AM |
| HEI distributor | haaslyd | Electrical | 3 | 12-16-2003 11:44 AM |
| HEI distributor | RodneyUSAF | Engine | 4 | 03-08-2003 04:56 PM |
