Distributor help..... - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2008, 01:08 PM
I am trying to get my 302 running right in my 89 Mustang and I think my friend who was working on it for me put my distributor back in wrong.
I think what I'm supposed to do is to find TDC and make sure the metal part inside the distributor is pointing to the number 1 cylinder, Im just looking for some verification....anybody know?
Also, I didn't know if this post should go under "electrical" or "engine" so I am posting it both places...thanks....
Old 08-24-2008, 03:03 PM
Jmark's Avatar
You are correct. Remove #1 plug and put your finger over the hole. Have someone bump the starter until your finger gets pushed out. At that point, you are approaching TDC on #1. Next, manually rotate the engine while watching the timing marks on the balancer. When you get them lined up, you are at TDC and can re-install or at least check where the rotor is pointing. It should be very close to the #1 tower on the cap. Start it up and set the timing with a timing light.
Mark
Old 08-24-2008, 03:20 PM
woodz428's Avatar
Troll Hunter
Don't forget to pull the spout connector prior to starting it to set the timing.
Old 08-24-2008, 03:50 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
You have it right, find TDC remember TDC comes up twice you need the compression stroke, there are two ways of doing this
one have the spark plug out on #1(front cylinder on passenger side of engine) put your finger in the hole & turn the engine over until you feel pressure pushing against your finger, then continue turning (by hand) until the pointer is at TDC, then put the #1 wire on the terminal the rotor is pointing at.
Or take the valve cover off & turn the engine until both valves on #1 are closed, bring it to TDC & connect the plug wire where the rotor is pointing. firing order 15426378 rotor rotation C.C.
Good luck,
Rich
PS This is an engine question
