Distributor help - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders Site Suggestions and Help
Old 08-24-2006, 10:59 AM
Distributor help
Greetings, Vacuum advance, test for dash pot, with vacuum applied unit pulls in and advance can be seen, but then slowly returns, vacuum has remained constant, has the dash pot failed?
Old 08-24-2006, 11:44 AM
Yes it has!
Old 08-24-2006, 12:33 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
This forum is for Site Suggestions and Site help........Your question needs to be posted in the Engine forum.
Old 08-24-2006, 02:40 PM
aka Duke of URL
Greetings
Vacuum advance, test for dash pot (vacuum motor), with vacuum applied unit pulls in and advance can be seen, but then slowly returns, vacuum has remained constant, has the dash pot failed?
More than likely, if the cannister holds vacuum, it is good. What you may be experiencing is binding of the breaker plates (not to be confused with binding of the shorts).
If they cannot move freely, they will limit advance and retard.
