Dots
Doc here
What your seeing I believe is the SAME optical illusion I saw... I downloaded your picture and ran it through Paint Shop pro7 and blew it up like 20 times..and measured with a straight edge..in the photo they line up..when you reduce it the cam dot looks like its off to the left... Try this if you can..get a laser level laser pen, and shoot a line between the two, if it falls between the center of the two , it can be nothing but lined up.. What concerns me more than that is the gears , especially the left gear show excessive signs of wear, the edges are worn and the teeth don't look to me like their meshing properly, AND the gap at the right seems too be to wide (another sign of wear and backlash..) In addition to that the massive amount of metal dust around the block area!! (unless that's a product of digi photography..you NEED to get that crap out of there...spotless! then new filter and oil, run a few minutes and change both again..That stuff CAN eat the rotating mass and cam bearings ALIVE! Clean it good get the bone and gears, do the oil and filter thing, and you should be all good.. Doc
Aftermarket Solutions Electronic & Electrical Innovations |
You can get a complete new gear drive set from Jegs They have a cheap one for $99.99, a Edelbrock for $159, and a Pete Jackson for $142.99. Judgeing by the gear wear etc. in the pics I think you need to do as DocVette says...clean everything up spotless , replace the complete geardrive, and change the oil and filter ASAP and hope that your cam bearings etc are not already damaged from all the metal particles.
Hey Steve,
Thanks for the reply. I really do like the sound, and check out the cardomain page and see the profile on it's set-up. I like to think it's a radical street car that is just as comfortable at the track. Now, if I can get it back together this year (Lokar throttle/700R4 cable install) I'll post some numbers. Again thank you for your input. Tom Quote:
I also agree that timing lights are made for a reason, and at least provide a good "known" starting point of reference for setting timing. I think everyone at one time or another has set timing by ear but I still dont recoment it! YThe problem in this thread would never have been noticed if he diddnt check the timing with a light. just my $.02 |
Bought up a pile o stuff
Will install the new parts soon. Made some myself also. Gear drive broke and threw everything off alot. Replacing everything with the best I could find, in my opinion.
| Links aren't attaching correctly | lluciano77 | Hotrodders Site Suggestions and Help | 2 | 03-05-2005 09:14 PM |
| Measuring track width correctly. | Huckster | Suspension - Brakes - Steering | 2 | 07-31-2004 12:06 AM |
| Valve cover won't seal correctly | Jag Daddy | Engine | 7 | 05-25-2004 12:48 AM |
| correctly placed cam bearings | 406chevelle | Engine | 7 | 01-03-2004 02:15 PM |
| How do I correctly paint a chrome bumper? | bukweet | Body - Exterior | 3 | 03-09-2003 07:26 PM |
