Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - distributor not seating properly on intake(sbc)
Old 03-08-2010, 07:39 PM
32Essex's Avatar
32Essex 32Essex is offline
Has the block been decked, Heads been resurfaced? Is the distributor fully seated or setting above the intake after it drops into the oil pump? You may need a distributor with a slip collar, or have someone make you an aluminum shim to take up the difference.
