Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Distributor Not Seating SBC
Old 11-15-2012, 06:37 AM
Adam65 Adam65 is offline
Did you make sure the gasket is still on the distributor? Once you do get it down, verify that the you still have some slight endplay with the shaft to make sure you are not forcing the oil pump shaft into the oil pump body.
