Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Distributor Not Seating SBC
Old 11-15-2012, 09:06 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
After you verify the distributor is correctly aligned w/the oil pump drive shaft, check that the distributor isn't bottoming out. If it is, it can be adjusted using nylon shims.
BTW, if the distributor wasn't lining up w/the drive shaft it should be a lot more than 1/32" above the intake flange.
The Following User Says Thank You to cobalt327 For This Useful Post:
Richiehd (11-15-2012)
