Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Distributor Not Seating SBC
  #16 (permalink)
Old 11-15-2012, 07:57 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 123pugsy View Post
And the verdict is in.
After fiddling around with it, the stars and planets all lined up and she dropped down all the way without a gasket.
I know its not binding as I can lift the distributor end play by pulling up the rotor. Its not being forced up.
I'm sure you're probably fine, but were you able to tell that there is more than just 1/32" engagement between the distributor shaft and the oil pump drive shaft? Like at some point did the distributor sit way proud of the intake (like over 1/4" or so) when the alignment between the two shafts was off?
Just checking, 1/32" is not enough engagement as I'm guessing you know.
