Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Distributor Not Seating SBC
  #17 (permalink)
Old 11-16-2012, 04:02 AM
123pugsy's Avatar
123pugsy 123pugsy is online now
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Originally Posted by cobalt327 View Post
I'm sure you're probably fine, but were you able to tell that there is more than just 1/32" engagement between the distributor shaft and the oil pump drive shaft? Like at some point did the distributor sit way proud of the intake (like over 1/4" or so) when the alignment between the two shafts was off?
Just checking, 1/32" is not enough engagement as I'm guessing you know.
No, it was just sitting up a wee bit.
I found my old gasket on the floor and found it was indeed squished nicely from when I took it out.
I'm sure its fine.
