Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Distributor Not Seating SBC
  #19 (permalink)
Old 11-16-2012, 01:03 PM
123pugsy's Avatar
123pugsy 123pugsy is online now
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Keep in mind that the problem was not that the dizzy tang was on top of the pump drive and had 1/32" gap. It was after engagement of the tang and pump drive that it was riding high.
Of coarse its about 1/4" up if I miss the alignment with the pump shaft.
After some wiggling and stuff it dropped right down onto the intake even w/o the gasket.
Maybe the pump rod was not exactly straight or?? when I was dropping it in?
I do know I am engaging the pump rod as I pulled the dizzy up and turned the pump rod 360* by advancing one tooth of the dizzy gear and dropping it back down each time.
I had forgot about this simple pump rod trick until I was fiddling with it. I didn't need a screwdriver or spare dizzy to line it up. DOH!
