Just checking, 1/32" is not enough engagement as I'm guessing you know. |
I found my old gasket on the floor and found it was indeed squished nicely from when I took it out. I'm sure its fine. |
I don't think I explained myself well enough. What I'm saying is, is when the distributor is put in "wrong" and the pump shaft is not aligned correctly w/the distributor shaft, the distributor- in that position- should sit a lot higher off the intake than just 1/32".
It should be at least 1/4" or more off the intake. If all there is is 1/32" engagement between the distributor shaft and the oil pump drive shaft when they're correctly aligned to each other, that is not enough.
Keep in mind that the problem was not that the dizzy tang was on top of the pump drive and had 1/32" gap. It was after engagement of the tang and pump drive that it was riding high.
Of coarse its about 1/4" up if I miss the alignment with the pump shaft. After some wiggling and stuff it dropped right down onto the intake even w/o the gasket. Maybe the pump rod was not exactly straight or?? when I was dropping it in? I do know I am engaging the pump rod as I pulled the dizzy up and turned the pump rod 360* by advancing one tooth of the dizzy gear and dropping it back down each time. I had forgot about this simple pump rod trick until I was fiddling with it. I didn't need a screwdriver or spare dizzy to line it up. DOH! |
That's all I was checking on. Good job!
Thanks for watching my back Cobalt.
| SBC distributor | truckerkev | Electrical | 7 | 11-05-2012 03:13 PM |
| distributor not seating properly on intake(sbc) | 84CHEVYSWB | Engine | 5 | 03-08-2010 08:21 PM |
| SBC Distributor | j_labossiere | Engine | 18 | 02-02-2004 09:58 PM |
| SBC distributor | GearHead69 | Engine | 5 | 08-22-2003 06:56 PM |
