Distributor Not Seating SBC
I just changed the cam on my 350 TPI. I dropped the dizzy in and there's about 1/32'' gap between the base and the intake.
Anyone have this issue before? Block and heads have not been machined BTW. Could the tang on the dizzy be sitting on top of the oil pump drive rod? |
Have you tried tapping it down a bit?...I have seen where its a tight fit and needs a little persuasion. Check to see if there might be something down there (gasket material etc)
Ontario Rodders |
usally if its not seating the pump shaft is not lined up. got to move the pump shaft a little so it will lineup. just got to play with it a few times. never goes in the first time. make sure the gear and oil pump drive have a little oil on them also a little oil on the top area where it sticks thru the block.
Most of the time this can be fixed by rocking the engine back and fourth a little. But dont turn it all the way over just give it a little bump to get it finally lined up. Just wiggle the crank a little dont turn it at all if the dizy gear is not lined up. Make sure the oil pump is lines up before you bolt it down. do not try to force it or hit the starter motor to get it seated. Does your car have an oil pressure guage? Also make sure the wire is connected for the oil pressure sender. You want to make sure at least the warning light will come on if the car has no oil pressure. |
Did you make sure the gasket is still on the distributor? Once you do get it down, verify that the you still have some slight endplay with the shaft to make sure you are not forcing the oil pump shaft into the oil pump body.
After you verify the distributor is correctly aligned w/the oil pump drive shaft, check that the distributor isn't bottoming out. If it is, it can be adjusted using nylon shims.
BTW, if the distributor wasn't lining up w/the drive shaft it should be a lot more than 1/32" above the intake flange. |
| The Following User Says Thank You to cobalt327 For This Useful Post: | ||
Richiehd (11-15-2012) | ||
Thanks guys.
Nice link for the dizzy wiki Cobalt. Looks like I may need some of those nylon spacers. Since I didn't do anything with the block, heads or intake, I was most likely driving it around with the oil pump drive shaft tight against the distributor tang all this time. This engine was not originally a TPI motor. I wonder if a different pump/drive shaft was used than what I'm running now. Maybe the L98 heads kept the intake higher? Do you think I grind a bit off the bottom of the dizzy tang? |
) or I'd check to see which it would be for sure.Hopefully driving like that hasn't damaged the oil pump. You can inspect the thrust washers/spacers on the distributor (between the gear and housing) for wear or damage/signs of overheating. |
Ah yes. If its the two tabs then the vinyl shims would be req'd for sure.
I'll take a peak at it later tonite. |
I was having a problem lining up the screwdriver to the slot so I took the gear off an old distributor to use as a tool to align the pump drive to exactly where I want it. I then pulled that and dropped my good dizzy in. Its going down all the way except about .030". I have at least .060" interference as I would assume about .030" required end play between the pump drive and distributor tang. Its definately dropping in with a thud, metal to metal contact. Thanks, Pugsy |
[quote=malc;1611543]
Smaller gap with 2 gaskets of coarse. |
I always measure mine without the gasket, and make sure the distrbuter sits flush and not in a bind. Then add the gasket, you know you wont be too tight. If necessary you can get the proper shims to shim that up 1/16th or so. then add your gasket. This way you know the oil pump wont be in a bind. Do it the right way first, dont be grinding on stuff to make it fit.
And the verdict is in.
After fiddling around with it, the stars and planets all lined up and she dropped down all the way without a gasket. I know its not binding as I can lift the distributor end play by pulling up the rotor. Its not being forced up. |
| SBC distributor | truckerkev | Electrical | 7 | 11-05-2012 03:13 PM |
| distributor not seating properly on intake(sbc) | 84CHEVYSWB | Engine | 5 | 03-08-2010 08:21 PM |
| SBC Distributor | j_labossiere | Engine | 18 | 02-02-2004 09:58 PM |
| SBC distributor | GearHead69 | Engine | 5 | 08-22-2003 06:56 PM |
