Distributor or Plug problem? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2002, 06:50 PM
54 Chevy's Avatar
Post Distributor or Plug problem?
What would cause my engine to want 20deg of timing cold and 12deg when hot? I mean it wont even start unless i move it to these two positions. I have an HEI distributor, AC Delco R45S plugs gapped to .040", 8mm wires.
Is this a case of plain old vapor lock or is something in my system changing with the heat? I'm not sure if I need Octane booster or to rebuild my distributor.
Any suggestions would be great.
Thanks,
Jim
Old 05-25-2002, 03:03 PM
aka Duke of URL
Question
Does the distributor have points, mechanical advance or does it have an ignition module?
If module...is it controlled by an ECM or have mechanical advance?
Old 05-25-2002, 03:15 PM
54 Chevy's Avatar
Post
HEI is a GM electronic distributor. No points. It does have a module on board the distributor. It also used a vacuum advance. I was used from 75' to some time in the late 80s.
Old 05-25-2002, 07:35 PM
aka Duke of URL
Post
Check the mechanical advance weights and springs. It sounds as though they are binding. It is a common occurence.
You may also have a bad module/stator. Are they aftermarket or Delco? Either (or both) may be bad but only show up with heat. Use a hair dryer on the module before starting and see if it is hard start.
What year is the engine? If it is mid-seventies, the cam timing itself will be retarded (assuming your timing chain is ok).
