distributor with points - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2012, 12:47 PM
Last journal entry: 1971 elcamino
what part on the distributor do i check to see if its getting power,and shouldnt i get spark at the coil wire to ground when the engine is being turned over. with the wire in the coil.I am not getting any spark.
Old 03-27-2012, 12:56 PM
Wiki Edits: 31
the wire stud on the side will have constant power. If your not getting spark, you have 1 of three issues. coil is bad, condensor is bad or points have no gap
Old 03-27-2012, 01:42 PM
lg1969's Avatar
Google "Tunnel Ram 406"
What year is the car?
Old 03-27-2012, 02:25 PM
points
I checked my points there was a hole burnt right thru the points i just put them in last year what would make them burn out so fast.
Old 03-27-2012, 02:29 PM
1971 elecamino-350
Old 03-27-2012, 02:53 PM
gto_ron's Avatar
You get 12 volts to the coil + side when cranking. It drops to about 7 volts when running. This is accomplished by the ignition switch feeding the coil from a regular wire when cranking or a resistance wire when running. If these wires are mixed up or the resistance wire is bypassed the points will burn up quickly. If your condensor is bad the points will arc and burn up also. Start with those two possibilities.
regards
Ron
Points style distributor issues apache235 Electrical 17 06-19-2013 01:05 PM
MSD 6AL to GM points distributor hotrod389 Electrical 11 01-20-2011 09:16 PM
67 distributor points Minace21 Electrical 2 03-24-2008 05:15 PM
Chevy points distributor identification abe Engine 2 07-30-2004 01:03 AM
Points distributor Camaro2Fast4u Engine 2 02-24-2003 04:48 AM
