Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 05-07-2008, 12:25 PM
jollyrogger jollyrogger is offline
distributor question
a guy told me that i can make my 350 run better at higher rpms by changing the wates in my distrbuter. is it true and will it make me lose power at the low end? or shorten the life of my distrbuter?
Old 05-07-2008, 01:24 PM
oldbogie oldbogie is online now
re: distributor question
Maybe make an improvement, maybe not, depends on what you're starting with, engine and vehicle.
Won't hurt the distributor but can hurt the engine if too much advance is put in too soon the engine will ping which depending on how hard and hot varies from an annoyance to holes in expensive parts.
Bogie
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
