Distributor question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2003, 06:43 PM
My engine fires up but the vacuum source is directly over a radiator to block hose connection. When i turn the dist. and reposition the wires ( in order), should i drop the dist. and point the rotor to the terminal on the cap that i am using for #1 again??
Old 08-22-2003, 07:02 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Answer is yes.
You can put the distributor in any location. The main thing is make sure its timed at #1, and wire it the same firing order starting at the #1 location. Hopefully it will get the hose away from the rad.
Luv the smell of NITRO in the morning.
