Distributor question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2003, 04:45 PM
I have an 84 K10 that is having some timming problems and I was wondering if the gear at the bottom of the distributor is supposed to spin both ways? I think that may be my problem but am not sure. U can either e-mail me at yogunna123@aol.com or reply to it here thanks
Old 09-30-2003, 04:48 PM
yes, the gear at the bottom of the shaft should spin freely in both directions.
Old 09-30-2003, 04:59 PM
I dunno I am havin a problem with my truck and it is all timming issue. It runs but just say if I try a brake stand it kinda back fires and dies. When I did the timming chain I yanked out the distributor and the mark I had on it wore off, I replaced the oil pump as well. When I did the timming chain I was told to put both the cam and the crank gear at 12 oclock with the engine at TDC. Does that sound right or am I wrong?
Old 09-30-2003, 07:08 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
If you had the timing set before you took it apart and set on top '0' the timing on the distributor for #1 cyl. has to be 10* to 12* advanced.
Usually set at the timing mark on the damper to the timing pointer tab.
Luv the smell of NITRO in the morning.
Old 09-30-2003, 08:15 PM
MI2600's Avatar
Member# 3287
I'm confused...both the marks on the cam and the crank were at 12 o'clock? They should have been pointing at each other..the crank at 12 and the cam at 6.
Old 10-01-2003, 05:37 AM
Yea I know all that but the thing is I had someone else helping me and I think they set the cam and crank to 12 oclock and I am wondering if the truck would even start at all or if u would have a back fire.
Old 10-01-2003, 06:02 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Yo...if you set them both at 12:00 then you better tear back into it. I would not think it would start but there is a remote possibility, especially if you moved the distributor around enough. Cars will run with a dist. 180 degrees off but not very well. Best bet would be to pull off the timing cover and check to see if it is correct. Not a fun job but if in doubt.......
Kevin
Old 10-01-2003, 06:04 AM
Wrencher's Avatar
Get #1 cyl. on tdc. comp. stroke, crank by hand until #1 intake opens and closes, then bring timing mark to 0. Pull the cap, rotor should be at #1. Then set timing with timing light. It won't run 180 out.
