Distributor Question 350 SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-05-2012, 05:43 PM
EazyDuzIt102's Avatar
1965 Impala SS Convertible
I recently dropped my 350 back in a few days ago. While I had the engine out, I replaced the timing chain and gears and all the gaskets and some other parts. I am ready to install the distributor and I was told by someone that when I drop it in, the rotor should be pointing at the #6 cylinder. I have always installed it by pointing it to the #1 and making sure the timing mark was on 0. The person told me to point it to #6 when he found out I replaced the timing gears and chain. Am I missing something here? Or is this correct?
Old 09-05-2012, 06:09 PM
Depends on how you left the timing gears. When the pip mark on the gears face each other (crank at 12 and cam at 6 O'clock position) the engine is ready to fire number 6 cylinder. If you rotated the engine one turn from there or assembled it so the both the crank and cam gear's pip marks are upright in the 12 O'clock position then it's ready to fire number 1.
Position the distributor housing so the vacuum cannister is pointing forward, then rotate the shaft so the rotor is pointed at which-ever cylinder will be on firing based on the position you left the gears in. Expect the oil pump drive not to mesh with the distributor drive gear in such away as to give you perfect body alignment. You can compromise the vacuum cannister location a little or reach down the distributor hole with a screw driver and turn the pump drive till you get the mesh you want. Be sure the distributor is meshed with the oil pump before tighening the hold down so you don't break parts. Don't forget the gasket that goes under the distributor or you'll have a little oil leak from the base of the distributor where it meets the manifold.
Bogie
Old 09-05-2012, 09:29 PM
SSedan64's Avatar
X2^^.
Install Tip >> Distributor Install (Tip)
350 sbc distributor brokenbones Engine 8 01-20-2011 08:01 PM
installing distributor/timing on sbc 350 075turbo Hotrodding Basics 38 05-19-2010 07:33 AM
SBC distributor question 72NTX Engine 1 10-15-2008 04:02 AM
Sbc Distributor Question...... STATUTORY GRAPE Engine 15 11-14-2005 04:04 PM
SBC distributor question Steve-0321 Engine 2 03-12-2004 09:39 AM
