Distributor selection for my old truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2006, 01:43 PM
fat50chevy's Avatar
New Member
Hello all, I need a little help in selecting a distributor or ignition for my old 50 chevy pick-up. It currently has a 350 in it with an HEI distributor. I like the one wire hook-up and it runs fine, but I have a firewall clearance problem. My plug wires are touching my firewall and will not allow me to fully rotate my distributor. I have researched old threads and looked in the knowledge base and I am no closer on deciding which route to take. 1. Do a little metal work on the firewall. 2. Go to an MSD ready to run, with an external coil, $400 bucks, and will that give me the clearance I need ? (Don't know) 3. I could slap a module in an old points dist. put a coil on it and screw up a new $85 set of MSD plug wires. My question is what has others done to solve this type of problem and if I go the MSD "ready to run" route where or how will I have to rewire my current system? I hope I have not confused everyone, and thanks in advance for your input and help.
Old 05-10-2006, 04:08 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
There are TONS of small body HEI's out there..Here is MSD..
MSD SMALL-BODY
This one requires a Coil, (external) and an MSD 6 series brainbox..Easy to do yourself and fairly Reliable.
Do a Goggle Search for Small Body HEI and see what is out there.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 05-12-2006, 02:45 PM
fat50chevy's Avatar
New Member
Thanks Doc, Done a quick search and will look some more. Thanks for your time and effort. I just want to get this truck to the point where I fill I can take it anywhere and I am very close to that.
94 chevy truck runnin' like poo! bluesmanjesse Engine 11 11-09-2006 03:54 PM
94 chevy truck maybe dist./ignition problem,please help! bluesmanjesse Engine 14 11-19-2004 04:31 PM
1996 Chevy 1500 Truck 4.3 V-6 Juicer Engine 8 09-28-2004 07:06 AM
Repatriated Cubans get new truck ! Rodrunner Hotrodders' Lounge 11 02-06-2004 04:20 PM
66 ford truck swapping a 240 i6 out for small block chevy igotachevyor2 Engine 0 04-14-2002 04:19 PM
