distributor whining - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2003, 10:49 PM
Question distributor whining
I have changed my original distributor "64"chevy "283" with points ,to a later "80"s H.E.I. fits good, runs well,but have whining noise,will a shim help ???
Old 01-11-2003, 04:58 AM
Post
Try a shim and see if the noise stops
Old 01-11-2003, 05:15 AM
aka Duke of URL
Arrow
There are two shim kits available for service;
  • Moroso 26140 for shimming the rotor shaft/gear for proper free play...
  • Moroso 26150 for shimming the distributor housing for proper installation depth/gear contact.
-Available From Summit Racing-
If the installation depth is not correct (dist. housing) it will press the rotor gears in the oil pump against the bottom housing causing a whirring noise.
