Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Distributor wire
Old 05-13-2003, 06:55 PM
PrimeMover's Avatar
PrimeMover PrimeMover is offline
Sittin' on top of the world...
Post
No. Zero resistance is not possible in any braided or solid copper conductor, but close to zero is good enough for a distributor lead. The longer the wire gets, the more resistance it will have. The resistance in a foot long piece of #16 braided wire is so miniscule, you'd need to set a digital Ohmeter on R times 1000 to detect it. Ballast resistors or "resitance wire" is used in-line at the (battery) positive supply side of the coil.
The distributor lead wire from the coil is simply a messenger to ground.
