Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Distributor wire
Old 05-19-2003, 04:10 PM
Mertz's Avatar
Mertz Mertz is offline
Post
The ground wire does exist but it is not the one causing the problem. The wire you are talking about goes from the breaker plate to a screw holding the vacuum advance. It is grounded to the boldy of the dist. The wire that is giving me problems is the wire from the points to the negative side of the coil. I will be eliminating it by going to the pertronix ignitor where only 2 wires are required.
