Distributor wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2012, 06:42 PM
byrddogg65
Distributor wiring
I am replacing a Mallory unilite with a new HEI distributor. The unilite has a 4 wire hook up and the HEI only takes 1 wire. All the wire have been spliced into and extended at some point. How do I find the constant 12v ignition wire? That is the wire I need to hook up to my new dist. 1968 Chevy Chevelle. Thanks for any help. Jason.
Old 08-09-2012, 08:12 PM
EOD Guy's Avatar
you don't want the constant 12v..... you want the switched 12v. Orig color was pink? I really don't remember but I think it was pink or black. Use a 12v test light to find the right wire.
Old 08-10-2012, 05:32 PM
byrddogg65
I found a wire that was hooked up to my unilite. It actually had 2 wires going into 1. It had power when the key was in the run and start position. I hooked it up and it will not start. Not even a pop. I separated the 2 wires and hooked up each 1 at a time, still no start. Is this the correct wire with power when key is in start and in run position?
Old 08-10-2012, 07:50 PM
EOD Guy's Avatar
Yes that should be it. Did yo make sure the coil contact was clean and had the spring installed under the cap? Is the ground wire hooked up? It also might be the ing module that's under the rotor plate.
Old 08-11-2012, 05:53 AM
SSedan64's Avatar
The Unilites require an external Resistor or the original GM Resistor wire before the Coil connection to lower the voltage, to about 9V+. Make sure you actually have full 12V+ going to the HEI.
HEI Conversions >> HEI Conversion
distributor wiring jasrking Engine 12 06-11-2009 07:20 AM
Coil/Distributor wiring fred56 Electrical 7 01-01-2007 05:34 AM
HEI distributor wiring macx Electrical 2 10-20-2003 08:24 PM
85 s-10 distributor wiring question strracer7 Electrical 1 09-29-2003 04:39 AM
SBC Distributor wiring???? Redshiba Electrical 4 09-13-2002 01:31 PM
