distributors - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2010, 09:40 PM
distributors
i am restoring a 1980 k5 blazer and i am going to put a tunnel rams with 2 4s on it ,, my question is can i run late model tbi distributor with this set up and if so what is the wiring as far as 12 volts go,, thanks
Old 03-28-2010, 10:00 PM
DoubleVision's Avatar
The TBI distributor has no mechanical advance, it`s advance is operated by the computer. You`ll need a small cap distributor from MSD or the like.
Old 03-28-2010, 10:53 PM
ericnova72's Avatar
More for Less Racer
Only way you can use the TBI distributor is with a programmable ignition box like MSD or Mallory Programmable models.
Or you could keep all the factory TBI injection and computer and run 2 TB's on the ram- if you are looking for a mechanical, electrical (and programming)challenge .
You can buy aftermarket small cap distributor or you can put an electronic conversion in the older, smaller, points type factory distributor too.
Old 03-28-2010, 11:47 PM
That sounds pretty cool Eric, I`d love to see a pair of TBI`s on a tunnel ram, that would look nasty.
Old 03-29-2010, 12:06 AM
ericnova72's Avatar
More for Less Racer
I recall seeing in-process pics somewhere of somebody doing this with factory TBI body's, and another with the Holley Pro-Jection 2 barrel and 4-barrel body's... just with CRS kicking in I don't remember specifics on the factory type set up or how it ran. One of the Holley 2 barrel type set ups was on a rock crawler/trail/dune type Jeep I saw at the sand dunes and he loved his set-up but admitted it took some time to get dialed-in by testing,... this was pre-wideband era but narrows were around. Probably be a whole lot easier today with a wideband O2, be done tuning in a couple of days
flat head ford distributors mikej6 Engine 1 07-22-2009 05:28 PM
Distributors! whats your favorite? poy41 Engine 12 06-22-2009 02:51 PM
changing distributors on a 289 tom penicaro Engine 1 06-14-2009 01:33 PM
Distributors MI2600 Engine 4 04-16-2007 12:40 PM
S10...V8 Conversion... Distributors?? TheZaZ Engine 11 03-22-2003 05:03 AM
