distributors v8 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2003, 08:19 AM
New Member
Post distributors v8
Yes I have a Chevy 4x4 350 TBI and I am changing it over to carb i finally got that figured out and I was wondering about the DIST I have now. Will it work with the carb setup or do I have to change it too? Its the stock dist that is in the TBI motor with the ignition module inside it..I need some ideas thats
Old 01-02-2003, 10:48 AM
Post
my guess would be yes it would work because with the EFI engines the distributor still sits down low as it would be on a carbed engine. maybe someone else around here knows. later
Old 01-02-2003, 02:08 PM
roys63's Avatar
Post
It will run with the injection dist, but not drivable if you leave the computer conected, you will need a HEI dist with vacume advance from 1975 to 1980 will work
