Ditching Power Steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2009, 04:46 PM
454headache's Avatar
Can the fluid lines to a GM power steering box ('90 C1500) simple be removed and plugged to make it a manual box? Or would this cause damage to the steering?
Old 10-27-2009, 05:09 PM
Last journal entry: frame build
I've done it short term to get home, but I don't think it would work long term because of the lack of lubrication.
Old 10-27-2009, 05:31 PM
sprecher48's Avatar
Oddo nut
Last wiki edit: VW engine basics
Last journal entry: note from the sandpit vol.#3
Location: sunny south(maybe rainy,haven't looked outside today) florida
Wiki Edits: 10
re: ditching power steering`
I think this would work just fine if you were popeye;otherwise it's a charles atlas course.tom
Old 10-27-2009, 06:44 PM
Would an S10 box work?
Old 10-27-2009, 10:03 PM
fast68's Avatar
likes chevy trucks & boobies
s-10 boxes mount to the inside of the frame rail
or at least is in comparison to the '87 older trucks anyways, in which didnt.
88-up full size i have forgotten
you would have to check pitman shaft splines and diameter, also the length of the box overall to see if the steering shaft would work
i have a '95 full size box and several s-10 boxes sitting around i can check...
because i have forgotten
if you need..
s-10 boxes mount inside the frame rail
the 87 older trucks mounted on the outside
so didnt interchange at all.
i think maybe they did move the '88-up full size boxes to inside the rail though
thats the thing i forgot..
even if they did it doesnt mean it will fit and work.
the only thing that interchanged before 88 was ones that were mounted on the same side of the frame rail
s-10 and cars were same
and only full size ones interchanged with each other
im not too sure manual steering was even available on 88-up
never seen or heard of one anyways.
if there are any i think they are super rare
or special order
why dont you just fix whats wrong and do it right?
steering is a safety issue..
not for only you and who you haul around but others out on the roads..
good used parts are dirt cheap at yards.
good luck
Old 10-28-2009, 12:34 PM
There's nothing wrong with it. I just do not like the clutter under the hood. I doubt that there are any manual boxes for 88+. I think I'll just loop the power steering box and if I do not like it put the power steering back on.
Old 10-28-2009, 12:51 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Ugh. I HATE manual steering on a pickup truck!
My old 66 was manual steering, and it was a WORKOUT to try to paralell park.
My wife refused to drive it in town. I am SO looking forward to having power steering and (hydroboost) brakes, especially since I swapped out a 250 for a 454.
Manual boxes usually have more turns lock-to-lock AND have a larger steering wheel to provide more leverage. My guess is that this experiment may be short-lived?
Old 10-28-2009, 02:14 PM
daoldbuick's Avatar
You don't even have to unplug the power steering hoses, Just try turning it with the motor off.
Old 10-28-2009, 02:25 PM
66GMC's Avatar
Not quite true, IMO.
If the hoses have been removed and the fluid inside the box has been displaced, it is much the same as manual steering ... except for the differences in the "lock-to-lock" gearing ratios.
Be sure to cap those inlet and outlet fittings after displacing the fluid, in order to keep the debris and moisture out.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Mustang/Maverick power steering oldred Suspension - Brakes - Steering 4 11-04-2007 01:01 PM
Power steering whine/lack of assist question '45 Ford Suspension - Brakes - Steering 7 07-05-2007 02:05 PM
power steering won't return to center powerrodsmike Suspension - Brakes - Steering 32 10-12-2006 08:22 AM
Power steering question chrisflock Suspension - Brakes - Steering 4 02-19-2006 02:31 PM
