Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ditzler DZL-72 red oxide primer-surfacer
Old 04-06-2007, 10:33 PM
baddbob baddbob is offline
Use it for a guidecoat, reduce it 100-200% with lacquer thinner and spray a light mist coat over your surface before sanding, it will highlight the low areas and any scratches, defects, etc... Lacquer usually doesn't go bad in a sealed container, if it mixes up fine it'll be OK to use as a guidecoat.
