-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   divilbiss and sharpe filter/reg combo the same thing? (http://www.hotrodders.com/forum/divilbiss-sharpe-filter-reg-combo-same-thing-229798.html)
jss 02-20-2013 05:47 PM
the 2 models are
sha6720 vs devhar602
http://www.andysautosport.com/images...m__sha6720.jpg
https://www.acklandsgrainger.com/ima.../DEVHAR602.jpg
are they not the same?
I am looking for a good filter/dryer system
was also thinking the sharpe 6760 if other thing its good quality.
http://www.northerntool.com/images/p.../406760_lg.jpg
jss 02-20-2013 05:51 PM
on a side note I noticed some of shape gear is blue vs light blue in there products is this a way to tell usa/china stuff?
http://images.myautoproducts.com/ima...A/SHA-6720.jpg
jss 02-21-2013 06:06 PM
here is another the same thing but made by astro
http://www.autobodytoolmart.com/imag...dium/14147.gif
69 widetrack 02-21-2013 07:05 PM
A trap/filter is an important piece of equipment for your shop, especially if your planning on doing any painting...if your not you can get away with one of the single filtering systems. The 3 stage desiccant system would be beneficial if you plan on plugging a paint gun into your air line and sure wouldn't hurt your regular air tools...if budget isn't an issue that may be a route you want to go. Sharpe does make some quality filtering systems. The Devilbus "Finishline" system is fine but as their "Finishline" paint guns, may be considered to be entry level.
Ray
Ray
tech69 02-21-2013 08:40 PM
The finishline filter is great for airtools but wouldn't paint with it. A 3 stage system is more ideal for painting. Nevermind the Astro.
69 widetrack 02-21-2013 09:02 PM
X2 on the Astro as well.
Ray
jss 02-22-2013 02:17 PM
I made a post on garage journal talking about this aswell
my lines are at 3/4" and was thinking to get the sharpe 707f
http://media.toolking.com/catalog/pr...ight_Drain.jpg
and beside that to install the sharpe 707c which is the coalescer
http://www.sharpe1.com/sharpe/sharpe...$File/6930.jpg
both of which are 3/4"
would this be a nice set up? price would be about $425
69 widetrack 02-22-2013 02:21 PM
The set up would probably be OK...the price??? I'd shop around a bit.
Ray
jss 02-22-2013 04:36 PM
the price does jump from 1/2 set up to 3/4 i can get
1/2" version with reg for 259. but i was worried the smaller sizing
69 widetrack 02-22-2013 04:47 PM
I'm going to save you $165...get a few reducing couplers from 3/4 to 1/2 inch, you won't notice the 1/4 inch reduction for the filters, most automotive shops are 1/2 inch line.
Hope this helps.
Ray
jss 02-23-2013 01:03 PM
i think your right just saying the 3/4 filter option since down the road if i up my compressor and sandblaster it will give me one less thing to have to redo
69 widetrack 02-23-2013 01:46 PM
The 1/2 inch will work fine...the only time it wouldn't would be if you hire a bunch of employees and the're all using air at the same time...but by then you'd probably need a bigger compressor...not to worry.
Ray
jss 02-23-2013 02:15 PM
really? thats good to know makes me feel better.
joe_padavano 02-23-2013 04:17 PM
I'd still like to hear an answer to the original question, as I too have wondered if the Devilbiss/Sharpe/Astro filters are the same or not. With the exception of the shutoff valve on the outlet, the parts look IDENTICAL. My money says that all three are made from Chinesium.
69 widetrack 02-23-2013 04:25 PM
It wouldn't surprise me one bit if they where all the same...on the outside anyway...the inside...well that would surprise me a bit. I've seen Astro tools that break by taking them out of the box...some look like CP...that's why I wouldn't buy Astro.
Ray
