Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Diy aglinement questions
Old 10-13-2012, 07:43 PM
timothale timothale is offline
Wiki Edits: 27
steering centering
You should be able to turn the steering one side to the other and count the turns, then center the steering gear, put the steering wheel on straight , then adjust the tie rods to give correct toe in, wheels straight ahead and not rub one side.
