Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Diy aglinement questions
Old 10-14-2012, 01:32 PM
timothale timothale is offline
Wiki Edits: 27
toe loaded
Just be sure the wheels are on the ground, bounce it a couple times to set toe, as a teenager I made the mistake of having the car up in the air, scrubbed the rubber very fast. I had set toe on the roadster with a beam axle up in the air. you can't do that with IFS.
