-   -   Diy aglinement questions (http://www.hotrodders.com/forum/diy-aglinement-questions-224967.html)
purple fifty one 10-13-2012 01:07 PM
Nova front end........Outer tierods I replaced and now wheel rubs frame when I turn 1 way not the other....Ok,I missed the count when reinstalling ends......one tie rod end is completely "screwed" No adjustment??? When I raise truck to adjustment so wheels turn r to L....it is not the same when I lower??? SO how do I start over?
purple fifty one 10-13-2012 04:05 PM
diy aglinement "Gone Bad"
Originally Posted by purple fifty one (Post 1598750)
Nova front end........Outer tierods I replaced an attemped toe in.... now wheel rubs frame when I turn 1 way not the other....Ok,I missed the count when reinstalling ends......one tie rod end is completely "screwed" No adjustment??? When I raise truck to adjust so wheels turn r to L....it is not the same when I lower??? SO how do I start over?
is there a way to center my steering?I have steering wheel in lock... wheels straight at all times????
timothale 10-13-2012 06:43 PM
steering centering
You should be able to turn the steering one side to the other and count the turns, then center the steering gear, put the steering wheel on straight , then adjust the tie rods to give correct toe in, wheels straight ahead and not rub one side.
S10xGN 10-14-2012 10:04 AM
I just went through this with my Maverick. Put it up on jackstands, measure the distance from the inner edge of a tire to the frame rail at full lock one way, then compare that to the same measurement on the other side at opposite lock. Now adjust the rod-ends so those distances are the same while watching how many threads are showing on each rod-end, they should be close to equal. You will also have to take your toe-in into account. I found it easier to disregard the toe and center the wheels first, then adjust the toe-in by making equal moves on both rod-ends until it was right.
Russ
timothale 10-14-2012 12:32 PM
toe loaded
Just be sure the wheels are on the ground, bounce it a couple times to set toe, as a teenager I made the mistake of having the car up in the air, scrubbed the rubber very fast. I had set toe on the roadster with a beam axle up in the air. you can't do that with IFS.
