Diy aglinement questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2012, 01:07 PM
purple fifty one's Avatar
Nova front end........Outer tierods I replaced and now wheel rubs frame when I turn 1 way not the other....Ok,I missed the count when reinstalling ends......one tie rod end is completely "screwed" No adjustment??? When I raise truck to adjustment so wheels turn r to L....it is not the same when I lower??? SO how do I start over?
Old 10-13-2012, 04:05 PM
diy aglinement "Gone Bad"
Originally Posted by purple fifty one View Post
Nova front end........Outer tierods I replaced an attemped toe in.... now wheel rubs frame when I turn 1 way not the other....Ok,I missed the count when reinstalling ends......one tie rod end is completely "screwed" No adjustment??? When I raise truck to adjust so wheels turn r to L....it is not the same when I lower??? SO how do I start over?
is there a way to center my steering?I have steering wheel in lock... wheels straight at all times????
Old 10-13-2012, 06:43 PM
Wiki Edits: 27
steering centering
You should be able to turn the steering one side to the other and count the turns, then center the steering gear, put the steering wheel on straight , then adjust the tie rods to give correct toe in, wheels straight ahead and not rub one side.
Old 10-14-2012, 10:04 AM
S10xGN's Avatar
Gotta love a turbo!
I just went through this with my Maverick. Put it up on jackstands, measure the distance from the inner edge of a tire to the frame rail at full lock one way, then compare that to the same measurement on the other side at opposite lock. Now adjust the rod-ends so those distances are the same while watching how many threads are showing on each rod-end, they should be close to equal. You will also have to take your toe-in into account. I found it easier to disregard the toe and center the wheels first, then adjust the toe-in by making equal moves on both rod-ends until it was right.
Russ
Old 10-14-2012, 12:32 PM
Wiki Edits: 27
toe loaded
Just be sure the wheels are on the ground, bounce it a couple times to set toe, as a teenager I made the mistake of having the car up in the air, scrubbed the rubber very fast. I had set toe on the roadster with a beam axle up in the air. you can't do that with IFS.
diy alignment ? LEROYDOZOIS Suspension - Brakes - Steering 11 09-07-2012 03:06 PM
DIY rebuild bigfoot9090 Transmission - Rearend 1 04-12-2010 08:10 PM
Diy Tig Travis Rankin Garage - Tools 18 12-31-2008 07:37 PM
Diy Converible Help !!! Augusto General Rodding Tech 12 10-31-2006 11:11 PM
Diy shiftlight taffy Electrical 3 09-06-2004 05:10 PM
