DIY alignment turntable plates - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2011, 07:10 PM
001mustang's Avatar
Always have redundant backup car support system to prevent injury or death.
These alignment turntables work so well I can roll front tires back and forth.
Name:	00 turn table.jpg
ID:	51400   Click image for larger version
Name:	0 Turn table.jpg
Old 01-06-2011, 07:18 PM
Old Fool's Avatar
Great concept! I'd spill the bearings all over the place,lol.
But you have me thinking, cut 2 10" od circles and 2 14" od circles, put the ball spacer plate with bearings in between, then weld some clips on the 14" hanging over the 10" so clumbsy me don't spill them.
One more homemade tool to put on the to do list, thanks
Old 01-06-2011, 09:16 PM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
I like it! For the past five years, I've used two 1-foot square floor tiles sandwiched together with a layer of grease between them under each front wheel.
How thick (heighth) are they?
Old 01-06-2011, 09:24 PM
001mustang's Avatar
1/4" plate steel top and bottom.
3/8" ball bearings.
1/4" cutting board bearing retainer.
Old 01-06-2011, 10:52 PM
Come on now tell use the truth your wife kicked your ars for cutting up that cutting board!
But honestly, that is the last material you should be using a nice knife on so hopefully you move up to a real cutting board.
Old 01-06-2011, 11:04 PM
001mustang's Avatar
That crappy plastic cutting board...fosgraph or something ...was cracked...good riddance.
Old 01-09-2011, 02:11 PM
001mustang's Avatar
Turntable Version2
Improved 20* print out to easily verify angle when doing Caster.
Think I will spring for the 1/2" Delrin ball bearings next time. I can see bearing wear from the 3/8" balls.
I like to settle suspension and roll tires back and forth frequently before collecting data.
ID:	51512   Click image for larger version
ID:	51513   Click image for larger version
Do Clutch Plates and Pressure Plates Have to be the Same Diameter? mrwumper Transmission - Rearend 3 03-30-2009 01:43 AM
Question re. alignment of guide plates v8hed Engine 4 08-21-2008 11:12 PM
Cam wear plates/thrust plates jakejake1966 Engine 3 04-12-2006 04:54 AM
License Plates MI2600 Hotrodders' Lounge 3 07-23-2005 09:35 PM
