DIY ceramic coating for headers - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2009, 02:06 AM
001mustang's Avatar
I recommend coating headers with a polishable ceramic coating instead of a high temp paint. I use Cerakote Chromex from an online electroplating supplier. Do blast your headers with an aggressive media to achieve a crisp blasted profile. Do not blast part with glass beads since beads do not provide a deep well defined blast profile and the coating may not adhere. 4 oz is enough to do a set of long v8 headers (2 wet coats using a 0.6mm airbrush). You may polish your baked (500F) headers with a sand blaster using glass beads at minimum operating pressure ( about 10 - 20 psi ) if you are satisfied with a satin finish that looks like cast aluminum. If you have the time you can polish them to a polished SS look. If you have access to a vibratory polisher then it is easy street to polish. If you want to coat the inside of the header then I would recommend sending your headers off to a reputable company. I imagine it is very difficult to maintain proper film thickness inside the tubes but some companies say they can coat the inside of headers. Don't forget to coat your header bolts...very nice!
Name:	1 braze cracks.jpg
ID:	38381   Click image for larger version
Name:	2 wet ceramic.jpg
ID:	38382   Click image for larger version
Name:	3 post oven n post bead blast.jpg
ID:	38383   Click image for larger version
Name:	5 install from top.jpg
Old 05-23-2009, 03:36 AM
SmokeShow01's Avatar
I like the attention to detail....says something about the person...
Old 05-23-2009, 03:39 PM
540neverdone's Avatar
Loves to spooge
I think the Jet Hot company can do the inside if you send it to them.
Old 05-23-2009, 05:31 PM
I am also very particular, but not in market to have inside of exhaust pipes coated. I was intrigued by the analysis of the surface being coated and how to prep. such said surfaces etc...this is the attention to detail that I like...I am a glass man, work with glass, do windows on a commercial level, work in the trades, so I have a lot of respect for the artisanship....i.e., attention to details....
Old 05-23-2009, 05:35 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
You are correct they can coat the inside. Cole
ceramic coating ram horn manifolds mrmagoo100 Engine 5 02-14-2007 10:19 AM
Ceramic coating Mikey_mike Engine 1 06-03-2006 06:54 AM
Header Clearance Issue/Question About Damaging Ceramic Coating. Ghetto Jet Engine 9 10-09-2004 01:45 PM
Ceramic coating aluminum heads AngliaBob Engine 12 09-26-2004 04:04 PM
ceramic coating jimbobneutral Engine 0 01-28-2004 02:19 PM
