DIY exhaust - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2012, 12:09 AM
DIY exhaust
I'm in the process of building a Lotus seven, with a Pinto engine. Needs info on manufacturing ( bending) the exhaust. Thanx!!
Old 01-27-2012, 01:04 AM
327NUT's Avatar
See www.stainlessheaders.com, they sell all types of tubing and mandrel bends.....also show video's online how to build a set of headers.
Old 01-27-2012, 08:14 AM
Irelands child's Avatar
It's actually pretty easy, though I probably wouldn't build an exhaust manifold. There are too many good ones(Speedway is one seller), even for Pinto engines to fool around reinventing that particular wheel. If it needs to be modified a bit, then you can do that easily. You need a MIG or TIG welder, a length of steel exhaust tubing and a selection of mandrel bends from some seller like Summit or Speedway. Stainless would be from another as mentioned above. Then it just takes time.
This is mine at the 'H' pipe forward:
....and from the mufflers back:
Had I not used the '32 tank, would have gone over the rear axle instead of below.
The only parts 'pro' made were two pipe fittings that instead of butt welding on the 'H' system, were expanded at a Midas for coffee and donuts for the shop help($5-$6)
Time to make, total - probably 20 hours or so.
Cost - about $100 for the bends and a 10 foot length of aluminized exhaust pipe and the SS clamps
Dave W
Old 01-27-2012, 08:58 AM
How fast is fast enough?
What pinto engine? 2.0L or 2.3L?
exhaust 1990cheyenne Hotrodding Basics 11 05-17-2011 06:49 PM
Changing exhaust to intake and intake to exhaust? BillyJoe Engine 3 03-28-2006 06:29 AM
exhaust cut out tincouch1 Introduce Yourself 1 11-14-2004 06:00 PM
Exhaust Help 81Blue Hotrodding Basics 16 11-09-2004 10:40 AM
Exhaust flow on side exhaust ZeeksChopShop Engine 0 06-03-2004 05:42 PM
