DIY Fan Setup Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2011, 02:39 PM
I currently have two fans which I have pulling fumes from were I paint. They seem to be about right, all the fog clears in a minute or so, but they do draw a lot of muck in through cracks in my shed, as I don’t have any inlet fans to pressurise the booth.
My question is, if I turn these fans around so they are blowing air into the booth through a filter, will they still clear the fog in the same time? Theoretically the same volume of air is entering the booth so will also be leaving it through another fine mesh opening I plan to have at the other end of my shed (without any fans on it).
Old 03-04-2011, 07:45 AM
302 Z28's Avatar
Should work fine, but you must use quality filters, not the cheap blue fiberglass mesh ones. 3M Filtrete filters are very good filters that will stop the trash infiltration.
Vince
Old 03-04-2011, 07:48 AM
delawarebill's Avatar
shed paint booth
i like to add that i'd be putting a hole in the side of shed and install the filter. the u wouldn't be sucking junk..
Old 03-06-2011, 02:45 PM
Last wiki edit: First paint job Last photo:
I used 2 box fans with filters pushing air in and filters on the exhaust outlet to capture overspray. I built an outdoor paint booth that worked really well.
Pictures and write up: http://chris66dad.tripod.com/id24.html
Old 03-06-2011, 02:48 PM
poncho62's Avatar
Wiki Edits: 5
Moving this to Garage-Tools section....better fit there
Ontario Rodders
Old 03-06-2011, 11:03 PM
I'm still debating the whole neg/pos pressure booth for the spring (Temporary, out of plastic sheeting). I think neg would be easier for me, as I have a large furnace fan with a pulley motor.. You couldn't find a way to seal it up nice?
454 setup question. nution101 Engine 4 03-24-2010 12:55 PM
Engine Setup Question !!! Ratoflic Engine 6 07-29-2008 05:53 PM
question about mp brakes setup 38 old coupe Suspension - Brakes - Steering 5 04-17-2006 01:18 PM
Nitrous setup question brainsboy Engine 11 04-06-2004 08:30 AM
Setup Question (already running) Got Squeeze Engine 3 12-14-2002 10:53 PM
