DIY Flame Thrower? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2010, 04:01 PM
DIY Flame Thrower?
I've always wanted one for my car, especially with the new exhaust on.
Exhaust setup comprises of full length headers, x-pipe, Magnaflows and side pipes. I also don't have a cats so there should be quite a nice amount of raw fuel coming out the tips.
I'm aware how they used to do it way back when, but I'd like a setup where I don't wash down my cylinder walls with raw fuel or have to pull on a choke cable (don't have one anyways). I know that if I put the plugs before the mufflers, I get a pair of dynamite sticks going off. Also wouldn't want to pull spark and interrupt my ignition. So finding an available/pre-made spark control box is challenging so I decided that I'd try to get informed and build on myself.
I am well aware or the injury and legal risks of using these and I'd like to state that the only time I'll ever use them is in a vacant lot, for show purposes, or at 4am on a deserted highway.
I found these plans and I was curious to know what you all might think?
For the time being, my main concern is the ignition part and not the actual injection of the fuel since I may never in fact get around to injecting fuel into my pipes. I do however welcome any and all comments regarding these plans and if they'll work, or is there a better solution.
Thanks,
Chris
Old 01-08-2010, 09:39 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
That will work, but you won't get 25 mpg with it!
Old 01-10-2010, 11:42 PM
So the sparking portion of the plans are supposed to work, right?
Now I have two more questions regarding fuel injection according to the plans.
Why do I need two NOS fuel solenoids?
And my second question is, will a 7 psi fuel pump be enough or should I find one from a modern EFI car?
Old 01-11-2010, 01:02 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
I'd say you will only need dual solenoids if you want individual control of each pipe/injector, otherwise, one solenoid, Y-ed off to each side would be fine, and 7 psi should be plenty. You will have to adjust your jet sizing to accommodate whatever pressure you use anyway, the diagram shows .010 and up, might want to start with about a .025 and see what that does. The higher the pressure, the smaller jet needed to produce the same amount of flow as a bigger jet and lower pressure.
Old 01-11-2010, 11:51 PM
Thanks for that Rickracer.
So my final question will have to be, since I have a side exit exhaust setup with only about 15" of pipe from the mufflers to the tips, should I have to worry about my mufflers blowing up vs. me having tailpipes?
Or should I simply only light them up while at speed?
Old 01-12-2010, 06:50 AM
Rickracer's Avatar
I'd make sure the nozzles are pointing out,
Old 01-14-2010, 12:42 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
I have doing my own research on this matter and have a few plans for ignitors to drive the spark plugs and all of them involve at least one IC or transistor, this drawings have none I don't understand how will it work, specially considering that the terminal #87 of the relays that are next to the capacitor is not connected to anything so what circuit will the relay close?
I don't get it...
Augusto.
Old 10-07-2012, 11:00 PM
[QUOTE=Augusto;1218219]I have doing my own research on this matter and have a few plans for ignitors to drive the spark plugs and all of them involve at least one IC or transistor, this drawings have none I don't understand how will it work, specially considering that the terminal #87 of the relays that are next to the capacitor is not connected to anything so what circuit will the relay close?
The relay doesn't close a circuit to 87 it opens one from 87a which makes a "pulse" in the circuit much like a flasher does for a turn signal. If need be I can explain this further.
I realize this reply will more than likely fall on deaf ears but it might help someone that is finding this post for the first time.
Old 10-07-2012, 11:06 PM
The dual solenoids are a safety control of sorts, last thing you want is a direct outlet to your fuel system if one of the solenoids fails to close. If you refer back to the diagram fuel flows from one to the other and then splits to nozzles.
Old 10-08-2012, 10:58 AM
I don't get it...
Augusto.
The idea is to make the relays "chatter" (i.e., flip off and on). This serves the same purpose as a set of points in that it creates a series of d/c "pulses" that are then "amplified" through the coil. That's all you really need to do. The drawback is that your pulses end up at the resonant frequency of the relay chatter (non-adjustable), but that's fine for this application.
Sometime I even consider doing this on my '64 Corvette. I have my exhaust crossover plumbed with an O2 bung for A/F readout (but unused) and I could attach a fitting for propane introduction just before the mufflers. But I sure would hate to burn the paint off the back of my car.
Old 10-08-2012, 08:52 PM
Augusto's Avatar
old and forgotten thread, but since it came out of the grave, I think I'm gonna build the circuit with the two relays, might be interesting, even if I don't make the flame thrower it may end up zapping some bugs, critters or some other funny s4!t.
Flame thrower exhaust Chris Kemp Hotrodding Basics 22 01-16-2013 05:22 PM
flame thrower kit yea or ney calimstng66 Hotrodding Basics 9 07-22-2004 12:04 PM
Flame thrower clip genochevy1 Engine 7 05-22-2004 05:49 AM
help on a flame thrower blueoval Engine 2 06-22-2003 01:01 AM
flame thrower BERN Engine 8 11-07-2002 06:33 AM
