Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - DIY Head Cleaning, crack detection suggestion
Old 05-30-2012, 08:06 AM
zildjian4life218's Avatar
zildjian4life218 zildjian4life218 is offline
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Originally Posted by OneMoreTime
Also remember to remove any freeze plugs in the heads and clean those passages as well..Looks like that kit is dye penetrant method which should work just fine..
Sam
I recently did a set of gt40 heads for a buddy and I took the freeze plugs out for those.... never noticed any in sbc heads. Is there anything wrong with the way I did these? I used 20/40 media switching to something a little easier on it
Edit: Also that crack checker says non ferrous metals so would that be cast iron heads only? no aluminum?
