Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - DIY Head Cleaning, crack detection suggestion
Old 05-30-2012, 07:21 AM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
Magnaflux is used on iron heads the dye penetrate on aluminum heads though the dye penetrate will work on both..Some heads have a pipe plug instead of freeze plugs..in any case clean the coolant passages as I am convinced the coolant passages can be plugged in some cases leading to overheat issues..Your methods should work fine..
Sam
