Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - DIY Head Cleaning, crack detection suggestion
Old 05-30-2012, 06:30 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by zildjian4life218
Anyone have any suggestions on better media for blasting? I will be buying glass media for doing aluminum pistons. Will this be better for the heads or is the 20/40 im using now okay?
I uses 40/60 but mainly because that worked better w/the low-end asperator-type set-up I was using at the time. 20/40 is recommended for what you're doing, but I would mask/plug off decks, guides, seats, and any other machined surfaces unless the surfaces were being renewed.
I'm sure you're aware of this, but use a respirator and hood along w/gloves and protective clothing to keep the silica out of and off of you.
