Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - DIY Head Cleaning, crack detection suggestion
Old 06-14-2012, 11:47 AM
zildjian4life218's Avatar
zildjian4life218 zildjian4life218 is offline
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
This is a picture of the setup I use in case anyone was interested in trying it. I changed it up from the picture. I have two pieces of 3/8" x 2" wide that go across with a patio block. Then the two heads sit on the patio block so that the burner flame isn't right on them and then the garbage can sits over the heads to help hold the heat in.
I originally didn't use the patio block and it was hard to keep the heads somewhat uniform. Now There is maybe at 15-20*F temp difference from top to bottom.
