DIY mandrel bent exhaust in a box - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-03-2013, 05:14 PM
Northstar T's Avatar
Gone sailing
Great looking jig! I like to use a reciprocating saw for most cuts, but the idea is the same. I haven't seen it mentioned yet, but it seems like a really good idea to use a sleeve inside the tubes on these things. much easier to do the welds, and not have the cracking issues on the ground smooth (thin) welds once completed. you can buy the sleeves, but I just use a size smaller ex tubing and cut my own.
sometimes you can't just go buy off the shelf headers (or intake tubes ) for your particular car/engine setup
  #17 (permalink)
Old 11-03-2013, 05:34 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Can't agree with the sleeves.
Spend any time you would fooling around with making or cutting up sleeves, practicing your welding instead, and you'll be further ahead.
Practice on scraps and watch that you're getting penetration gribnets on the inside of your tubes and when you grind off the proud, there will always be full weld left behind right through the material.
Name:	IMG_2561 (Medium).jpg
ID:	95578   Click image for larger version
Name:	IMG_2562 (Medium).jpg
ID:	95586   Click image for larger version
Name:	IMG_2563 (Medium).jpg
  #18 (permalink)
Old 11-03-2013, 05:51 PM
Gone sailing
[shrug] agree or disagree. doesn't matter to me. I prefer using the inserts, even though my welding skills are second to none. just like yours.
BTW. I can still piss further than you can.
The Following User Says Thank You to Northstar T For This Useful Post:
123pugsy (11-03-2013)
  #19 (permalink)
Old 11-04-2013, 06:10 PM
ogre's Avatar
the 'Duracell Project'
another nice fixture pugsy, i'm ripping that one off too
sometimes a straight line and a chop saw is all you need for a good cut.
i do enough of this stuff to use a similar angle finder as the pivot.
dang, i do like this site. 2 good fixtures in this thread.
The Following User Says Thank You to ogre For This Useful Post:
64SS327 (05-05-2014)
  #20 (permalink)
Old 11-04-2013, 08:17 PM
Last journal entry: New Rev wheels and BFG KDW II tires
Nice jigs guys! And to think I was eyeballing everything when I marked and cut the pipes. Still came out nice but took way too long.
pugsy, those are some dang nice looking headers!
The Following User Says Thank You to 64SS327 For This Useful Post:
123pugsy (11-05-2013)
  #21 (permalink)
Old 11-05-2013, 08:25 AM
Marking Jig
Thanks for posting the jig pics.
I'll have to try something like that next time.
I cut all my bends with a zip cut disc.
I did make up a jig however to draw accurate lines.
Nice marking Jig Pugsy! I love making things that make my work go smoother!
The Following User Says Thank You to 38project For This Useful Post:
mandrel bent metal radiator hoses? pixelmonkey Engine 7 05-21-2012 11:12 AM
3" Mandrel Bent Exhaust Comments Please? Fastest65 Engine 3 03-11-2010 06:13 PM
Mandrel Bent Exhaust Fabricator PatM Engine 7 10-20-2008 01:07 PM
Mandrel bent vs. muffler shop bent cool rockin daddy Engine 31 08-02-2006 05:46 PM
Vega box pittman arm shaft is bent!!! HB32 Suspension - Brakes - Steering 1 05-31-2002 02:56 PM
