diy masking station ideas? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2013, 08:07 AM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
Ok so I thought about buying one of those masking stations for all of my diffrent size paper but I don't like giving up the floor space&since I'm doing the epoxy floors&tearing out all my old shelves&building new work benches I figured I'd incorparte a homemade systems into the work bench.Basically I'm gonna use 2x4s on the end of work bench &use some dowel rods or pipe..but what I'm caught up on is what can I use that will be stationary to cut the paper nice&clean?
******************** I've thought about getting some thin board&gluing box blades between two pieces but I'm hoping one of you guys have a better idea?I need something like they have on the masking station or the box of wax paper@the market.
What ever it is it needs to last awhile as it will see a lot of use.I'm open to any ideas thanks.
Old 03-05-2013, 12:51 PM
sedanbob's Avatar
How about a section of a band saw blade? Even small band saws have blade that are plenty long enough and a small toothed blade should cut nicely for a long time.
The Following User Says Thank You to sedanbob For This Useful Post:
Trucknut (03-10-2013)
Old 03-05-2013, 01:36 PM
Here is a picture of mine, I made it back in high school about 35 years ago. This is before the days of cheap stuff from China so I bought the rollers and tensioners from the local paint supply and built my own frame. If I remember correctly i used two hacksaw blades pop riveted together but at a later date I replaced it with a section of band saw blade. The tensioner for the blade is a hacksaw cut in two welded to the frame.
The Following User Says Thank You to Larry123 For This Useful Post:
John long (03-05-2013)
Old 03-05-2013, 04:02 PM
two cups of tea
Wiki Edits: 2
Hey fellas thanks!I think I have what I need now.I have a box of bandsaw blades I'm not using&some hacksaws collecting dust.
Old 03-05-2013, 07:59 PM
put up or shut up
I would just get a stand with three rolls on it with also an easy edge on it as well. Then I would make a wall mount for the widest roll with a tape roll holder and jagged edge to cut the paper. I would do it this way because sometimes you want to move the masker to where you are at or move it out of the way to keep it clean. The big wall mount would simply be doing what manufactures don't...design good masking machines for the big pieces of paper. I've seen one once in a shop and all other shops just I've seen just use their leg to cut the paper and ad tape themselves.
Old 03-05-2013, 09:08 PM
two cups of tea
Wiki Edits: 2
Im picking up materilas this weeknd I've decided to build it on a rolling workbench
Old 03-05-2013, 09:44 PM
I am posting a number of photos of my favorite in case you wanted to make one. If you do I can give you the specs. But honestly, I have done this a long time and used about every masking machine made including none at all using a 36" roll and a razor knife to cut what I needed. This machine is without a doubt, nothing more to talk about (in my opinion) the absolute best hands down. Sorry for the crappy photos it's dark when I get home and I wanted to get these up for you to see. But this think is the bomb, it has a 3", 6", 12", and 18" rolls. It doesn't fall all over when you tear the paper like a lot of them, I can pull off a piece of paper 15 feet long and tear it off from 15 feet away, I am not joking. It simply is the best. I couldn't fine one on line, don't know why, are they not available anymore? Don't know the name, maybe it's on it? Hmmmm, didn't look.
Old 03-05-2013, 09:50 PM
I see that it has a sticker on the bottom, I will get it's name tomorrow if it can be read.
Old 03-05-2013, 09:56 PM
put up or shut up
just like what I'm talking about but with an easy edger on the top. There's no need for nothing more really.
Old 03-05-2013, 10:07 PM
two cups of tea
Wiki Edits: 2
Thanks Martin Summit has one similar but its straight up.
Old 03-10-2013, 08:55 AM
deadbodyman's Avatar
Wiki Edits: 11
Heres the one I use every day..I made it about twenty years ago...It used to be straight but it fell of a truck I was taping...All it is is electrical conduit and conduit couplers (cut in half) so I can adjust where the paper roll sits and adjust where the tape roll sits. for the tape holder I used the plastic ends that come with a roll of plastic sheathing(perfect)to cut the paper I welded hack saw blades on the rod which are hood props..I always wanted to make another one that didnt look so homade but this works so well I never needed to ...holds 36" on the bottom ,18" and the top one, any of the narrower papers...
I only buy the 36" rolls because I can cut the the paper to any size I need on my band saw..
ID:	72171   Click image for larger version
ID:	72172   Click image for larger version
Old 03-10-2013, 09:46 AM
put up or shut up
nice. One thing I hate about them is when people don't take care of them and things become loose and wobble around, which allows the tape to wander on the edge of the paper. Oh man, that's annoying! for personal use and for a lack of garage space, I just use the old 3m hand dispenser which I used for mobile painting a couple years back. More work but I need the space in my garage.
Old 03-10-2013, 01:47 PM
I finally got the name off it, Vantage Tools.
http://www.terrys.net/CATALOGS/VANTAGE.PDF
And ALC Keysco 33004 Vantage Paper Tree Masker | Paint Prep, Masking
They aren't cheap, $300 but you know what they say about quality stuff, you have to pay for it.
Old 03-10-2013, 02:52 PM
Wiki Edits: 11
They arent cheap but I am...I might have a twentyspot into this one..plus an hour or two in labor
Old 03-10-2013, 06:23 PM
I hear ya, I don't know how good yours works but I am not kidding, I have never used one that works better than this baby. You can honestly pull the 18" paper out and walk 15-20 feet from the thing pulling it, give it a snap and it tears perfectly. It is an awesome tool.
DIY ideas for a long flexible sanding board? JohnnyK81 Garage - Tools 6 06-07-2011 05:15 PM
Help with my astro masking station?? angel85lx Body - Exterior 3 01-11-2011 11:40 AM
Masking Off...? SHIFTY101EASY Body - Exterior 8 02-03-2007 02:01 PM
masking alden Body - Exterior 6 06-15-2005 08:18 AM
masking flames phatwagon Body - Exterior 11 08-08-2004 07:57 PM
