DIY Paint Booth air. Furnace Fans? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2011, 09:54 AM
So I need to build a paint booth in the spring for the Mustang. I was going to go the PVC tubing and plastic way, but I still have exhaust to think about. So I found a good deal on a large furnace fan with a pulley driven fan, so no explosion, however, it then occured to me that it's a rather large fan, and I don't want negative pressure in the booth.
So should I try to find a bigger fan for the intake (Which wouldn't have to be explosion proof I suppose), or should I just use this fan as the intake, and have no outlet fan (Just a couple of filters). I'd be afraid of getting too much pressure in there and the booth either flying apart (Being plastic sheeting, and all), or just not having adequate exhuast.
Ideas, thoughts?
Old 01-26-2011, 10:57 AM
boatbob2
Paint Booth.......
Hi,i would make the paint booth out of pvc and plastic,same as you.make a wooden frame to mount your fan,staple or tape plastic to frame,on other end make another wooden frame,and mount 2 large AC filters to the frame,again staple or tape plastic to wood,make booth at least4 ft larger than car (i prefer 6 ft larger) you wont need a fan by the end with the filters...WEAR A RESPIRATOR.2 or 3,, 8 ft long neon lights (mounted outside top plastic) makes seeing the car easy..ive been there and done this...works great.
Old 01-26-2011, 11:57 AM
Wait, so you have the fan pushing air in, then exiting through a filter, or going through a filter, then exiting through a fan?
Old 01-26-2011, 12:15 PM
Underground's Avatar
Last journal entry: 54
Florescent lights not neon
Old 01-26-2011, 12:47 PM
milo's Avatar
point on positive
Depending on the paint type you use sometimes it's possible to not run the fan(s) all the time.. If your doing a base coat then clear coat for instance it is ok to put the base coat on in still air and just run the fans a little between coats. This will minimize air movement and dust/dirt movement as well and what little over spray that does settle back onto the car will even help build the color coat. It is during and after the last coat of clear that it's important to get the cloud of over spray away from the car.. Less is better when it comes to wind in the paint room.
Old 01-27-2011, 07:34 AM
gto_ron's Avatar
Milo
I have a negative pressure DIY paint area, are you saying I only need to run the exhaust fan after the final coat of clear?
thanks for any advice
Ron
Old 01-28-2011, 07:10 AM
milo's Avatar
point on positive
Yes ,,you'll be able to judge between base coats if the fan needs to go on to clear excess fog.. Remember to not open the door with the fan on.
Have the door at the downwind side of the car so the moving air doesn't drag debris onto the car when you move through the door..
Have the intake filter/opening at the opposite end..
Start clearing at the upwind end of the car near the filtered intake opening working toward the exhaust end..Run the fan during and after clear until the room is over spray empty and then turn the fan off and don't go in there for a while..
Old 01-28-2011, 09:18 AM
I've painted many cars using box fans blowing out without filters on them. The whole "risk of explosion" concern is overblown paranoia. The only concern using uncovered fans is the paint building up on the motor over several paint jobs.
Old 01-30-2011, 12:32 PM
Silverback's Avatar
Boost Retard
It's possible to get enough solvent in the air to have an explosion, but by the time you do you won't be able to breath in there, even with a good mask. Basically, if you're still conscious it's not going to to go boom... not even close
Old 01-30-2011, 06:19 PM
cheap paint booth
I went to home depot and bought a cheap 1 car portable /tent like garage. It was under $200 with the sides. Bought a roll of furnace filter material and used a box fan to blow in and create a positive pressure. Make sure to filter the incoming air and create a filter for outgoing so you don't over pressure. Worked well and now I have a tent for yard parties.
Type of paint for Paint Booth SuthnCustoms Body - Exterior 4 10-11-2010 05:47 AM
paint booth turbo t Body - Exterior 1 04-10-2009 08:52 PM
Paint Booth hallamwillis Body - Exterior 2 04-21-2005 04:45 AM
squirrel cage fans for my garage "booth" SWITCHCRAFT Garage - Tools 1 08-08-2004 07:47 AM
PAINT BOOTH GIRLWITHTHANOVA Body - Exterior 3 10-05-2002 07:23 PM
