Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Do any of these blocks come with the fuel pump hole correct?:
Old 08-28-2012, 09:13 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is online now
It is a hit and miss situation on one piece seal blocks. It depends on the application that the batch or production run of new engines was originally intended for. Some are fully drilled with a plate over the area and some are blank. You can't go by casting nos. No particular rhyme or reason. To the aftermkt user.
