Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Do any of these blocks come with the fuel pump hole correct?:
Old 08-29-2012, 10:00 AM
BogiesAnnex1 BogiesAnnex1 is offline
Originally Posted by s10mikey View Post
in 86 is when thay came with the trottle body injection,, and the fuel pump was put into the tank,, you would be better off just to run aftermarket electric fuel pump,,
Funny how things change, when I was a kid, the electric pump was considered an improvement for the often tempermental, failure and vapor lock prone mechanical pump. Finding an electric feeding a set of Stromberg 97's was the hot set up.
Bogie
