Do electric choke coils go bad? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2013, 10:34 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
Do electric choke coils slowly go bad, or do they die all at once? I removed the coil from the carb and wired it directly to the battery. It took quite a while but eventually it moved, barely. I gave it about 10+ minutes and it moved about 1/8". Granted it wasn't in the choke housing, so some heat was lost.
Maybe that is all they are supposed to move and my linkage is worn out...?
Old 06-14-2013, 08:18 AM
RWENUTS's Avatar
What did you ground it to?
Old 06-14-2013, 09:03 AM
One side of the battery to the pig tail connection.
The inside of the choke plate cover has a metal contact the seems to ground directly to the carb body. I hooked that up directly to the battery as well.
Before this I did verify that there was continuity with a multimeter. I think it was around 15ohms
This is for a Q-jet carb, btw if that matters. And I also verified the pig tail does send a full 12v under normal operation.
Old 06-14-2013, 02:50 PM
ericnova72's Avatar
More for Less Racer
I've seen them do both types of failure. Hey, it's an electrical component....just sayin'.
Old 06-14-2013, 09:09 PM
Irelands child's Avatar
Assuming the internal connection is good, then yes, they can fail. Since it's a bimetallic device it will either break, usually near where it's hooked to the +12VDC input or distort/bend from overheating
Irelands child
electric choke vs manual choke jrbaker Hotrodding Basics 5 05-20-2013 07:15 PM
changing a divorced choke to a electric choke? Help please?e 71GMC Engine 1 02-11-2012 05:14 PM
electric choke rneiden Electrical 8 02-27-2011 08:05 AM
electric choke njbloodline666 Electrical 15 05-02-2006 05:55 AM
Electric choke 3100 Special Engine 10 04-23-2006 08:46 PM
