do i or do i not run a radiator - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2012, 03:33 PM
I have a methanol engine for drag racing that has never heated over 150degrees. I put it in early model mustang. Putting fuel system in front. Don't want radiator unless absolutely have to any ideas
Old 06-07-2012, 03:56 PM
dawg's Avatar
NAVY VETERAN
must use a radiator.
why?
heat builds in a short time between the cylinders.
Old 06-07-2012, 05:11 PM
Banned
just run it with coolant but no radiator, its nbd. just don't leave it on for a long time.
Old 06-07-2012, 08:49 PM
454 Rattler's Avatar
NEVER SATISFIED !!
Are you allowed to use a tow car ?
454 RATTLER
Old 06-07-2012, 10:39 PM
Wiki Edits: 27
epoxy block ?
I had a couple friends that poured the blocks full of the heat absorbing epoxy and just run coolant in the heads. The Epoxy mix can absorb a lot of BTU's, with less temp rise. The block was still warm on a monday noon from the sunday drags. A hemi and BBC race only engines
Old 06-07-2012, 10:54 PM
Wiki Edits: 27
Jewel T
Joe Davis had a battery and starter and reverse in his record setting T altered, Most of his competitors were push or aux start. At one champ race the other guy kept having "trouble" getting staged jumping out then killing his engine then getting a push start. He wanted Joe to overheat. Joe just shut the T down and waited then He played the game and the other guy over heated and his engine was detonating on the run.
No-radiator Bonneville run question Zeeb Engine 0 05-02-2012 06:34 PM
How to run radiator hose to back of VW Ponderosa General Rodding Tech 9 10-21-2011 10:36 AM
radiator pressure to correct radiator cap lb pressure lildrip049 General Rodding Tech 6 10-17-2011 12:31 PM
4.3L chevy doesnt run right after frozen radiator etc, fast68 Engine 13 03-04-2010 07:22 PM
how much HP to run 12's, and how? hotrod66_57 Engine 5 07-30-2004 12:42 AM
