Do I have Dart heads. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2003, 06:25 PM
My boy bought a truck 70 chevy short bed and was told that he has Dart heads. We are not sure and I tried to get info from the Dart sight without any luck. we had the valve covers off the 350 engine and the numbers we found there were W H23 94 S?R I-052 NH
Can anyone deciefer this and have clue to the type of heads on the truck. They have screw in studs with folded metal roller rockers. Our concern is that we get the correct intake gasket to get rid of the leaky intake manafold. Thanks sorry I could not find anymore information on the heads. Ed ke6bnl
Old 10-29-2003, 06:31 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
It would be better to measure the runner opening when the intake is off in case they we're opened up, and look and see where it was leaking, if the bolts were not torqued down but tightened instead, it can cause the seal between runner's to split.
A Fel-Pro gasket # 1205 or 1206 will be the correct one, the specs on a Fel-pro's site for the opening should be given.
Luv the smell of NITRO in the morning.
Old 10-29-2003, 08:11 PM
Inside the valve covers it will say Dart or WP for world products. Either way it will be a 1205 felpro.
Cstraub
Old 10-29-2003, 10:01 PM
Jared's Avatar
those are world products S/R torquers. good heads, thats what im running on my 355. my numbers are
W 96 S/R
G24 NH I-052 I think you might have a diff chamber size or something I cant remember what the 96 and 94 mean. look it up on google I found lots of info on them on there. good luck
